BoatingCop
- Aug 28, 2007
- 408
Re: Resto/Rebuild 1973 Johnson 40hp!
Ok, so I pulled the head today (the bottom starboard head bolt is a PITA by the way!!), and found the cylinder walls to be nice and smooth. The pistons just have some build up on them which I assume is normal.
In the next pictures you can see my tester adapter stuck in the #2 hole. I'm taking it to the machine shop where they can hopefilly fix it and clean it up.
I also figured out where my lower unit was leaking fluid from. It looks like the prop shaft seal, as thee was quite a bit in the pan that the LU was sitting in. How difficult is it to change the prop shaft seal?
