Replacing sound deadning foam
BRICH1260
My Chaparral Sunesta 243 has a black eggshell foam that is glued to the lift up engine cover for sound supression. The foam has begun deteriorating and crumbles when you touch it. Can this easily be replaced, if so where would you purchase it or is their another material in use today that would work better or be easier to work with?
oops!
Re: Replacing sound deadning foam
i like that stuff.......works great.....
it can be purchased at a foam shop ....or from crate packing companies.......it is just glued on
