AgainstTheWind13
- May 29, 2016
- 9
Okay, it's true. By nature, I'm a dumpster diver. There's something about bringing a basket case back to life that always gets me going, and I've really bitten off something to chew this time. This winter, I stumbled across a 1996 Crownline 202 Bowrider project boat with good lines and lots of problems. The hull and transom? Solid. Engine? Cracked block! And the floor? Ah, the floor. It's the usual, for a 20 year old boat from an owner that didn't have sense to cover it and shield it from the weather. So now I'm opening her up for renovation. At this point, engine is out and a new build is underway. The Alpha One outdrive was geared for a 5.7 Mercruiser, and that's what's going back inside. I looked for a suitable block for a month, and located a great one, with the help of a very good independent boat mechanic. He's currently building the engine.
Now it's time to replace that floor. Like many boats of this age, pulling back the carpet revealed floor (sole) rot on the panel that covers the fuel tank, and there was also some rot on the insides of the ski locker. I've now pulled enough of the flooring off to see that while the stringers aren't completely rotted, there are spots, and everything under there is waterlogged. I've decided to replace stringers as necessary and the floor on top of that. As I began to figure out how to do this, I came upon the string posted by Badfish95, and it has become one of my best sources of knowledge. I still have questions, and I want to make sure I get this right. Help from you guys (a lot of you seem to have done similar projects) would be great. Here's where I am:
? I've begun tearing out, and have thus far siphoned and removed (and cleaned) the fuel tank. Along with the transom and engine mounts, the rear floorboards on either side of the engine seem to be very solid, so I was thinking of beginning my stringer and floor replacement from there forward. I've fully exposed the bulkhead that separates the fuel tank area from the engine compartment, and that piece of 3/4 inch plywood is water-logged and soft. To you and all the guys who have done a floor replacement, do you see any problem with this? I've been studying the stringer layout, and it seems that it shouldn't be too hard to double the thickness of that bulkhead and connect to the area behind. Agree or object?
? Also, wondering if I can stop my floor board cut somewhere BEFORE the outside edges that meet the boat hull. I'm concerned about gouging the hull. Thoughts on cutting up to the fiberglassed blocks that extend from the walls to around four inches inward?
? Finally, I was wondering how to connect the stringers together, pre-fiberglassing. Badfish's photos look like the stringer pieces are individually cut (versus some sort of interlocking). Should I just glue them together to hold them in place before doing all the peanut butter and fiberglass?
Thanks for any info - AgainstTheWind13 (new to the forum!)
