Ran amazing then shake no thrust
MikeyArriva
No I'm not going to say it again, but
Throttle moves and cable doesn't move at the motor. If this is the case then need to reconnect the cable at the motor
it is connected just not moving out. I had to pull on the red connection part (sorry sounding like a fool) when it was in forward to get it to come out and open
alldodge
ok, deep breath ;)
Lets start with the basics.
Unless you have a helper, disconnect the throttle cable at the carb. Need to remove a 7/16 self locking nut and remove a carter pin hold the barrel nut and cable will slide off.
Once off,hold the top choke plate open with one hand and open the throttle all the way with the other. While opening the throttle see if fuel squirts down the throat of the carb every time you open it.
MikeyArriva
not showing my last reply. does the cable need to be replaced then maybe? and how did it go at all lol. it is all connected but when i push the throttle forward it didn't slide out. I had to go manually pull it out
MikeyArriva
ok, deep breath ;)
ok. I will do that in the morning. when throttle was in forward i was able to pull it out and yes it was squirting gas for the 3 times i moved it in and out
MikeyArriva
ok, deep breath ;)
really appriciate your help and patience with me lol
alldodge
I'm old and not clear on if the cable is moving or not when the throttle handle is moved. If it moves then its not the cable. You also just mentioned that you saw gas squirt in, and if that's the case then its not gas
nola mike
We're trying to figure out what's wrong...
AD wants you to disconnect the cable so that we can concentrate on one at a time. If you disconnect the cable at the carb, the core of the cable should move freely when you move the throttle at the helm.
Back at the carb, the throttle blades need to open and close freely when you move the linkage; most/some of the time, the choke needs to be opened before the throttle will open all the way.
MikeyArriva
The cable is not moving when handle is moved. But when put it in forward i can go to the back and manually pull the cable out
alldodge
Might be the anchor set screws backed off and center wire slipped out.
Remove the cable and plastic guide from the carb and see if it comes off when pulled
MikeyArriva
Will it advance the throttle when you push the throttle only button?
working nights this weekend but will check when i get home. This one has the pull out style for neutral throttle. not a button
flashback
I'm not familiar with that, probably much newer design, my 95 has a button..it may help you.
Rick Stephens
Mine is an 89. You pull the whole throttle stick out and then forward
I have the same one. Back when I bought this boat, I recall perfectly how stupid I felt when I didn't think it even had a throttle only button. Is not really evident function :^)
MikeyArriva
was too tired to get into anything this morning.. will do tomorrow when i get home. did notice that this old style is bolts on front and back. took a few pictures I will see if i can figure out how to put them on hereboat engine top view.jpgBoat engine throttle cable.jpgBoat engine throttle cable and carb.jpgBoat engine 1.jpg
flashback
Your pictures are fine, you may want to grab a shop vac and clean up a bit then lube the linkage, may not solve the problem but couldn't hurt..
MikeyArriva
yes it def needs to be cleaned up.. crazy winds right now with cover open the last few weeks tryin to fix it up and it got coated.. just went for a test after getting it back from marina. She will def be all cleaned out before taking it to the park for the rest of the summer if I can bring her back to life
MikeyArriva
so the upper shift cable and throttle cable were obviously changed before I bought it to a different style.. there is no set screws or adjustable barrel like the lower cable. these have a small nut up against the plastic connector. you loosen that nut then spin the end to adjust instead of spinning the barrel. so many strange things
