Prestancia electrical problem
spacecrew
Hi,
I just purchased a 1989 Prestancia 30ft. While cleaning/inspecting, I found the terminal strip (located behind the aft closet and shower area) melted at a few connectors (see photo).
It looks like the problem started at the "Outlet Port" which I assume was caused by too much current. My first thought is to just replace the Terminal Block with a new one (and inspect the wires of course). Any other thoughts or things I should check?
Thanks.
David.
CHIEF915
Re: Prestancia electrical problem
Make sure you check it for shorts. Also if you are in the water fix it as soon as possible, I had a AMP in my boat that shorted out and then ate the drives up from the galvonic corrosion caused by the short.
jhackl
I would also check the circuit breaker for this circuit to make sure it is functioning properly. I have the same boat and had the exact same problem although mine was not quite that bad and I was able to move circuits 3 through 5 down to terminals 5 through 7 and not have to replace the terminal strip. Looks like it may be a problem area that needs to be checked regularly.
Isn't it fun getting in there to work on this :rolleyes:
Also make sure the other terminals are tight while you are in there. A loose connection at the terminal would cause this.
