Pre Alpha "R" Drive
Kjeremy2
Ive Determined I Have A PreAlpha Drive Because The Top Of The case Has a Hole in it and the side by the drain plug is rough. I'm not sure of the year but the upper unit has a serial # 3252209 I Cant Seem To find any parts using that could it be wrong? also on the lower unit the top shaft spins but the propeller doesn't is there a shear pin inside of this that could be broken or is the gears inoperable? thanks in advance for your help :D
Re: Pre Alpha "R" Drive
Ayuh,.... Donno why ya posted this in the Outboard forum, but I moved it here for ya,...
There's No such thing as a Pre-Alpha,... You have an MC-1 drive,...
My guess is, the lower unit is in Neutral,... Shift it into gear to lock it up,...
Kjeremy2
thank you sorry about that. Its Off The Boat Sperated because the impeller in the water pump is toast… is there a way to manually put it in gear?
Ayuh,... Turn the shift shaft ahead of the drive shaft,...
redneck joe
sterndrive engineering dot com. Great help for me on two of mine.
Kjeremy2
thank you so much if i could hug you right now i would cause i was thinking the gears were shot but it turned when i turned the shift shaft but it kept turning in my hand as i was turning the drive shaft is this normal?
Kjeremy2
Sounds like you should probably visit the "adults only" sticky at the top of the mercruiser forum (click on the hyperlink below) and do some reading/research and get ahold of a free outdrive service manual from that link for your particular drive. Good luck!
http://forums.iboats.com/mercruiser...tdrives/adults-only-no-exceptions-288430.html
might sound stupid but how do i determine the correct manual for my drive since idk when the drive was build but the boat was built in 88.
ktbarrentine
I cant seem to get that drive serial number to come up in the catalogs.... (3252209). Is that the number on the side of the outdrive, or on the transom?
Kjeremy2
Thats from the side of the outdrive. id upload a pic for verification but i keep getting an error every time i try.
ktbarrentine
I use photobucket dot com to manage my uploads. Free and easy.
Kjeremy2
These Are The Photos Of My Outdrive.
wrench 3
From the pictures you definitely have a MC-1 upper and lower unit, sometimes referred to in the Sierra parts catalog as simply a #1.
I would be curious to see what the rest of your drive assembly looks like, because as far as I know the MC-1 was out of production before '88. Although not recommended, the MC-1 drive will bolt up to the bell housing on the gimbal assembly of the Alpha-1.
Ayuh,.... Manual #1 should cover yer drive I believe,.... Possibly #2,...
Alpha 1 came out in I believe '83,....MR before that, 'n R before that, so the MC-1, or #1 drive ended 'bout '79 or '80,...
All 4 of 'em will interchange uppers, 'n lowers, or as complete drives,...
Kjeremy2
is there a way to download these manuals? so i could get it too a print shop and have it bound with laminated covers?
Kjeremy2
The Serial Number on the transom is OC382340 as far as i can read.
wrench 3
I can't get that serial number to come up anywhere. It would be more useful to know if the trim sender is on the side of the Gimbel ring or on a cylinder inside the boat attached to the inner transom plate. Also, the engine serial number.
Kjeremy2
The only number on the motor is imprinted directly on the motor so I believe this is the casting number..... would that help?
Ayuh,.... It appears yer motor, 'n transom assembly are original to the hull,...
Just a MC-1 drive bolted onto it,...
You'll find links to any, 'n All the info you need or want right here in Don'S Adults Only section, Mercruiser Info,...
The drive ya got will be covered in Manual #1, or #2, or #4, dependin' on how old the MC-1 is,...
Have ya looked in any of the links provided in this thread,..??
