chelseamad7
- May 9, 2013
- 27
Re: Please help Figure this one out,your a hero
Check your pulses on fuel pump,pull plugs and put to ground,take off fuel line going to carb.Put the end of the line into plastic bottle/containor,turn engine over for 15 seconds,while watching the constant fuel pumping.It MUST be constant.
Multiply by 4 this will give you pluses/per min.I have 1973 9.9 electric start and mine gives out 128 per min.
This then will tell you your pump is ok.Hope this helps.
The Rube Goldberg would it be the same fitting on my tank and screw a barbed fiitting onto that and attach fuel hose to that? If so how do i attach it to the motor where my original fitting is bolted on?
