North Beach
- Sep 29, 2008
- 2,022
Re: out drive removal help
Good Luck with it Kelly!
Well here is what I have been trying and not going anywhere. Just cannot believe that this damn thing can be so freaking stubborn is all.
http://s866.photobucket.com/albums/ab228/kcherry62/1967 Starcraft Islander
I have been following along and man do i feel sorry for you. I have been in situations like these where an issue at the beginning of your project can ruin the whole thing.
Is HEAT an option at this point ? Or maybe heat with dry ice ?
KellyC,
My outdrive was stuck in place earlier this year because water got into the u-joint bellows. What happened was the drive shaft kind of rusted to the transmon bearing so the drive line would not slip out of the bearing. I got mine off with several chisels and as soon as I got a open gap I started using thin pieces of metal to protect the alum outdrive and bell housing. As soon as I got a big enough gap I used a bolt on each side with a nut and another piece of metal I used the threaded bolt to press the outdrive off along with a ratchet straped hooked to the outdrive like shown in a previous thread.
I am not sure trying to pull the engine will work if your driveline is stuck on the bearing like mine was.
The shift rod should be lined up forward so it will slip out of the groove as you remove the outdrive. Then there are the 6 nuts that hold it on. I would not use any heat on anything.
Once you get it off, one place water leaked on mine was around the shift shaft seal, there is an upgrade seal that you will want to get, it is a good double lip big seal.
You could unbolt the transmon bolts and pull the drive off the boat with the transmon bracket, this would require you to support the engine from the inside.
