Ok how bad did i screw up.
scott8058
Tonight when we were coming in to the dock i went to put it in reverse to slow down but my motor was trimmed very high and i didn't stop and hit the metal on the end of the dock (probably only doing 5 mph). Its a fiberglass boat and it put a quarter sized deep gouge in the front of it. Its not a hole but the paints gone and you see fiberglass, it happened toward the top of the boat at a point that sits a few feet above the water and there are no cracks coming off of it. My question is how much do i need to worry about this and is there anything that i could paint over it to repair?
Lyle29464
Re: Ok how bad did i screw up.
Most likely just seal the glass so you don't get water in there. Sounds cosmetic to me. Now you can have fun with out worrying about that first ding.
scott8058
Well lol its a 95 so it has lots of 1st dings and scratches, the front is pretty scratched up so i know im not the 1st to do it. This is my first boat and the reason i didn't buy a brand new one! What can i use to seal it up, im new to all this!
Thanks
Lyle29464
take a picture of it to west marine. They will sell you a kit with some resin and hardener. That will seal it. They also have the top coat ( gel coat) you get to play with colors.
scott8058
here is a pic of the damage.....i think it attached, but like i said the front was pretty scratched up to begin with.
rivermouse
Thanks
Easy fix...Go to auto zone and get a tube of "water weld" epoxy putty...Pack the putty into the hole and lightly sand it smooth after it drys....This patch will never come out or leak......
scott8058
Ok cool ill look into that, thanks
superbenk
MarineTex is good stuff too. Mix the hardner in, apply the paste, rub smooth with a dripping wet hand & let dry. Not as hard as water weld, but may be a slightly nicer finished product.
roscoe
not to worry.
scott8058
Lol nice one roscoe.......oh and go Bears!!!
Don S
Moving to Boat Restoration, Building, and Hull Repair
