classiccat
"Captain" + Starmada Splash Of The Year 2020
- Dec 20, 2010
- 3,409
Re: My First StarCraft; 1975 18' SuperSport
I am Mucho-impressed with Gator finishing disks (used in a 4 1/2" grinder)! (12/31/2013 EDIT: Do not use gator disks on this surface! I had to replace the adapter plate due to very subtle dishing. Use razor blades & acetone. The longer Irwin blades work best. It takes longer but it preserves the true surface & the machining which gives you a better seal on the gasket.)
Excellent at removing gasket residue from the powerhead & exhaust adapter surfaces (use the Fine for this!!).
Stripping 2 layers of paint? Pishaw...and this is with the fine pad (prep for fixing the damage):
I can't wait to see what the "Course" Gator disk leaves in its wake!
After stripping the paint, treated the area with West Systems Alum Etch / passivation followed by a healthy smathering of JB.
Once I get this smoothed-out, its getting capped with 0.090" aluminum.
![](http://i1310.photobucket.com/albums/s658/classiccatCB/1975%20STARCRAFT%2018ft%20SUPERSPORT/0527121320_zps306cfda5.jpg)
![](http://i1310.photobucket.com/albums/s658/classiccatCB/1975%20STARCRAFT%2018ft%20SUPERSPORT/BFHTrial_MG_1031_zps9cf00d3b.jpg)
![](http://i1310.photobucket.com/albums/s658/classiccatCB/1975%20STARCRAFT%2018ft%20SUPERSPORT/BFHTrial_MG_1033_zpsea003fcd.jpg)
