D
Deleted member 340796
Guest
Re: My first boat restoration, I need some guidance - PLEASE HELP!
Well, it seemed a good day so we talked it over, practiced and just did it. Only problem we had was Joyce (my extra hands, ruined a shirt). I guess that makes it a positive day over all. It went really smoothly. We used 4 qts total as I poured the 4th down the winged out parts on each side (you will see what I mean in the photos). It gushed out of all the right areas so I think we are good. I will still need to put some more around the edges and bottom for fillets but I think that gets done in the next step (I hope) as I tab it in.
My thought at this time (I need to review some other threads to confirm) is tomorrow I can take the clamps off after 24 hrs. I can wait 48 or longer if that is better. Once the clamps are off, I will grind down the edges and clean it up good and prepare to tab it in. Things I need to figure out for sure:
Am I doing 1 or 2 tabs? I think 2 (one about 6" wide and 1 about 10" wide) and let it dry.
Next step, grind it down again, clean, then cover the entire transom with a sheet of cloth & glass. Since I am using epoxy resin (and have 10 oz and 1700 biax no mat) will I fully cover the transom with 10oz or 1700 or both? Also, will this cloth extend out past the 10" tabbing or just over transom itself?
I am going to post another message so I can add a few other photos and ask some questions related to the stringers and ribs.
Ok, so here come the photos of the work progress today. Yet another "rite of passage"!
As always guys, Thanks so, so much!
