my first boat 1962 mfg
stretch8668
Re: my first boat 1962 mfg
unfortantly i have no where to put the motor if i take it off so ill just have to drill some holes on the inside of it and then fill them in with epoxy if its good then paint over them.please correct me if im wrong cause i know nothing about boats.:D
stretch8668
also is there any way i can hook up a modern temp gauge from say a car and what about a tach? i just dont like the engine over heating light thats on it id rather like to be able to watch the temp instead of when its to late.
stretch8668
My dad and I tried getting this old girl running yesterday with no luck. I had to run jumper cables from the starting system to the battery in my truck and it was rotating but no go. So we ended up taking carb off sprayed everything out with carb cleaner and a hole next to the float was plugged up. Ended up putting everything back together and. Took cover off the top to get debirs out but gotta take nut off gears that I believe is a 1 or 1 1/16. And it wasn't getting spark so we got new plugs that r a little hotter(j8c instead of the j4c that was in it) for now to try and get it runnin. Any ideas how to trouble shoot ignition on it.
sphelps
Start a thread over in the Johnson/Evinrude forum and I'm sure those guys can get you headed in the right direction .
stretch8668
Got it going; had to take carb off and clean it out and took flywheel off and cleaned up points with sandpaper. She ran pretty good for 50 year old motor just gotta get new head cause it loses compression out of spark plug. Now just gotta get seats, fuel tank (thinking on 15 or 18 gallon plus 6 gallon spare) and I'm gonna use battery out of truck I had.
stretch8668
How would I hook up rope to tow a inner tube on this boat. Is there something particular I have to get?
sphelps
2 of these or something similar installed on the transom..
Bow/Stearn eye...
Woodonglass
6" in from the sides, 6" down from the top Through the transom.
stretch8668
Thanks again I'd be lost without this forum
Awesome boat! Reminds me of a buddy's project boat... sadly he had to give up on it due to $ and sold it for pennies.
I am excited to see all the supportive responses, too. Building community is critical to success and I am excited to move forward with my own projects and get involved.
Looking forward to the after-pics! :)
stretch8668
How would I mount pedestal style seats in boat? Would it be fine just to screw them to the deck or would I have to reinforce where I mount them.
sphelps
I would make a pad out of plywood cut the edges on a 45 deg angle seal it with glass then glass it to the deck where you want the pedestal .
Maybe 2 layers of 1/2 " or 3/4 "..
Woodonglass
Like sphelps says,pads is the way to go. Use Stainless T-Nuts then Stainless nuts to bolt the pedestals to the pads. Something like this would work great...
stretch8668
Would one piece of 3/4" be fine, and the t nuts are those the ones the spring out when they go threw the hole.
Woodonglass
I'd highly recommend 2 layers of 3/4" and these are T-Nuts...
images
sphelps
Do those come in ss ? And how in heck do you install?
stretch8668
By the looks of them they go under the wood and you nail em to it with holes drilled for the pedestal correct me if I'm wrong.
GT1000000
Here's a rough sketch, hope it helps...
stretch8668
Do I bolt the plywood to deck or. Just Fiberglass over it
