my first boat 1962 mfg
stretch8668
Re: my first boat 1962 mfg
I aLso have holes in deck from the sun n fun seats and from pedastals. Either way there's no way I'm getting rid of boat cause it means to much to me.
GT1000000
Is there any way I can dissolve it with an abrasive, gas or something
Unfortunately the foam can only be "dissolved" by removal with a variety of specialty tools; any, all or some of the following are highly recommended...a spade shovel, a claw hammer, a wonder bar, a chisel, a crowbar, maybe even a sawzall with a short blade to break it up into smaller sections and lots of cussing and sweating...:eek:...gasoline and a match work, also...but could be very detrimental to the boat, the surroundings and you...:p
Have Fun!:D
stretch8668
Not what I wanted to hear. If I cut 2 foot long hole that went the width of deCk think would be big enough to pull it out. Do you have to put new foam back in and where can u get it. Would I just have to patch it back up with glass AnD resin.
GT1000000
Sorry for the bad news, but it is what it is...
As far as making a hole and trying to dig it out...it is possible, but I am not familiar enough with the construction of this boat to know for sure if you will be able to reach all of the foam from one access opening...
Maybe one of the the other guys, who are more familiar with this design will chime in...
As far as replacing it, I personally would recommend very highly that you do replace it as it is used as a safety feature in the event the boat ever gets swamped and it may also be structural to this design...
You would need to find out the density of the foam originally used...it could be 2 pound, 4 pound or even 8 or 16 pound foam, I am not sure...
It is available from several sources, one of the best known ones is US Composites, but I think Iboats may carry it as well...
Woodonglass
Stretch, since your deck is a molded liner from the factory as one piece you will need to cut it along the edges and remove it in total. If you are careful you should be able to put it back by repairing the cuts.
stretch8668
If I cut 2 holes in back of boat to let any standing water out and patch em back up would iT be safe to stilldrive. I'm asking cause I'd hate to take entire floor out and mess up putting it back in.
stretch8668
Been while since last post so here it goes.I wanna get some shine back on this old boat I was thinking bout using some. 1-2000 grit sand paper on it and wet sand it then follow up with some nufinish (as I've read good things bout it) also gonna start with seats as soon as snow melts ( gotta love nh). Guess just wondering what other people use on faded gel coatad don't wanna 're paint it like to see it as original as possible.
Woodonglass
You might try a buffer and some polish first...
autogeek_2256_32280341
Toad64
friscoboater has some great videos on his you tube channel on how to get the shine back.
stretch8668
Would that 3m stuff also work on motor to get some color back
Woodonglass
HMMM possibly but with the grease and the Grime Motors are another Kettle of Fish
stretch8668
I ended up washing and waxing the boat I used attwood cleaner wax gonna do another coat and finish it off with polish.
stretch8668
I'm starting to fix this ole boat up I got the pulleys and cable on its way and the head gasket and other gasket on head. Next I'm gonna replace control cables but I want to make sure I get rite ones the cables read : morse 33m 13ft 2bh and morse 33m 12ft 2bh
stretch8668
Here's few pics of cables
Woodonglass
I have the exact same motor. I have the manual if you want a copy, PM me and include your Personal email address and I'll email you a copy of it. What Cables are you referring to...The Throttle cable??? Is your motor the Selectric 3 button Electric Shift or the Manual Shift?
stretch8668
It is manual and need both cables (forward/reverse and throttle) are u referring to manual for motoras I have that one
Woodonglass
Yeah the Motor Manual
Check eBay under Vintage Evinrude/Johnson Shifter Cable. You might get lucky. :D
stretch8668
Another Question the wire coming outta head is that for the over heated dumby light.
