my 14' tom boy project
varns
Re: my 14' tom boy project
They were only 1" tall and 1 1/2" wide in the old tri hull
craigweaver
Lookin good varns! I've been watchin your progress and hangin around. You got the right man givin you advice. Wood has been a wealth of knowledge for a lot of us.
Can't wait to watch her come back to life!
Woodonglass
If the stringers are only that tall then I'd use the Pink or Blue slab stuff from the Big Box stores
varns
Thanks Craig i would have never been able to even began to try this without this forums help and heap of knowledge it has to offer. The day she floats again shall be glorious
varns
Gotcha Wood Thanks again:D
varns
Here is what i did today Moving along real smooth
varns
Ok Wood so i was looking at your drawing on how you build your transom and it shows two layers of 1708 first layer i assume goes cloth side out right. On the second layer is were my question is do i put the CSM out or cloth side out when layering 1708
Woodonglass
CSM side ALWAYS goes down. The styrene in the Resin actually dissolves the CSM and makes it one contiguous liquid with the resin aiding in the bonding with the previous layer. Scuff the transom with 60 grit when you're ready to lay the first layer and then just as soon as you lay the first layer of 1708 get the second layer ready so when the first layer sets up and is still tacky lay the final layer of 1708 that way they will bond together as one.
varns
alrighty i know i keep asking tons of questions but i want to be 100%. Also want this to just as perfect as humanly possible
varns
transome install.jpg me and my dad put the transome in last nightshe pulled up nicely with woods clamps
Woodonglass
Transom looks outstanding and the filleting too! Very Nice Job!!!!!!
varns
Thank you very much it feels good to be putting her back together
varns
Anyone have any tips and or tricks to cut my pieces of glass to fit the hull on the inside of the transom so I have no wrinkles. I was going to try to cut it like I was laying a piece of carpet laying around stairs
Woodonglass
Cut it so it will wrap around the sides about 8" and down onto the bottom 8". Use masking tape to tape it over the top of the hull and let it drape down to the bottom. Cut out the center "Dip" section leaving 2" extra. on the bottom cut the corners so you can overlap them and make the corners lay flat. Use your hands and and a paint brush to smooth it all out during your "Dry Run". Once you've got it in place and it seems to fit like you want it start Rolling on your resin from the top down. I always have a chip brush on hand to "Dab" the corners in and keep em tight. Make sure you've got enough resin, Inside the boat ready to be Mixed so you can keep going once you start. Have your bubble roller handy too!
varns
Thanks thats a big help me and my dad are going to knock that out this weekend unless it rains..i was looking at this floatation foam on marinefoam.com and wow that stuff is quite pricey $92.00 for a 2'x4' sheet 2" thick does that sound right just seem high for foam but i really have no idea. i live in the "STICKS" so finding a Big Box store could be hard to do
Woodonglass
Lowe's or Home Depot is what I meant by a Big Box Store.
varns
ooooooooh wow i never hear them referred to as that so just that pink or blue insulation board gotcha
varns
Ok I have a question about my stringers originally when I removed them they were placed in random places on was 2" off the transom one 2I 1/4 2 1/2 just no consistency at all should I just run with 2" or extend them to the transom
