Motor year??
Re: Motor year??
thank you i found the pump but in the picture it doesn't show the glass bowl its just the metal piece of the pump with a gasket the part number is 861676A1.
Ayuh,.... There's no Glass bowl,... just a metal cover, 'n strap over the fuel filter,...
Kjeremy2
Re: Motor year??
Does that come with or do I have to find that separately just a little confused on that.
Re: Motor year??
Ayuh,... The fuel pumps most usually come Complete, just lackin' the fittin's to attach the lines,...
Glass hasn't been allowed on a marine motor's fuel system since sometime in the '60s,...
Kjeremy2
Re: Motor year??
I received my new fuel pump today i was wondering how too put it together everything came with it i just don't know which fitting is in or out they are marked on the pump just the fittings aren't. just looking for some guidance i have a new outdrive coming next week also i can't wait for this winter to be over so i can get to work. Also is there a reason i received a cork gasket instead of a rubber gasket?? Does anyone know the standard size for the overflow line coming from the carb to the fuel pump?
Re: Motor year??
Ayuh,.... Configure it Exactly like the one on the motor, that yer replacin',.....
Nothin' wrong with cork gaskets,...
Clean the surfaces, 'n use the gasket dry,...
The over flow plastic line is, I believe 1/4" tygon tubin',...
Kjeremy2
Re: Motor year??
alright thank you sir can't wait for warm weather now lol
