Re: MFG Gypsy 15 Tri-Hull Restore advice needed
Ignorance - a lack of knowledge, stupidity - the inability to use knowledge.
I'm using a Ryobi Hand grinder with a 4", 1/4" thick grinding wheel. Using it mainly for "scuffing up" and removing imperfections in the old glass. You can also get "Cut-off" wheels which are about 1/16" thick to cut areas (like along the edges of the floor) with. Because they are so thin and easier to break, Cut-off wheels can be dangerous. ALWAYS WEAR SAFETY GLASSES WHILE GRINDING!
In grinding fiberglass, being careful is the thing. Fiberglass is relatively soft compared to metal and it doesn't take much pressure to do the job. The weight of the grinder itself is sufficient to do the work. There are 2 things to keep in mind about the grinding itself. The face of the grinding disc cuts slower due to the larger surface area. The edge of the disc cuts much faster because it has the smallest surface area and highest rpm at the outside edge of the disc. It's the edge of the disc that can get you in trouble real quick.
Practicing on a scrap piece of fiberglass or piece of wood should give you an idea of how it feels and differences between using the face and the edge of the disc. Fiberglass will cut a little faster than wood.
I also highly recommend you read the Sticky at the top of the Restoration and Building thread related to Grinding Safety.
Almost forgot. If you're going to be purchasing a grinder and other power tools for fiberglass work, don't buy the best you can find! Buy the cheaper mid-grade tools. Fiberglass tears up bearings and brushes eventually. It's better to burn up a $60 tool that does the same job as a $120 tool!
