Re: Intex Mariner 4 modifications and Tips
When using the M4 with pedestal seats installed, I didn't feel the need for an extension (in the seated position). However, I did spend about 30min standing in front of the rear seat and an extra 8" would have been nice. Seated, I actually retracted the stock telescoping handle to its minimum length and angled it downward because it was too long. So seat configuration may alter your needs.
I noticed some forum contributors mounted their battery near the bow to distribute weight more evenly. I plan to explore that idea further using 8g jumper cables next time I go out. My battery is the heaviest single piece of equipment, the motor being second, so it does seem to make sense.
@dancor --- My riptide 50 has 1-5 forward speeds. 1-4 seams to be more for trolling. When you transition from 4 to 5, the motor increases significantly. Its too early for me to judge the battery draw, but I will take note when I am out next. I also need to learn more about the trim/shaft angle. The motor mount does flex into the boat when I kick it into speed 5. this changes the angle of the shaft. Just an observation. I wonder what the sweet spot is for this.
			I saw this when I was buying my seat:
Minn Kota 18" Extension Handle, MKA-18: Fishing & Marine : Walmart.com
