Interesting article about tank condensation
jmarty10
Re: Interesting article about tank condensation
It seems like the guys who have fewer problems are the ones in the cold northern midwest. On the Atlantic coast it's a constant problem.
I think thats exactly the case. I ran my boat last week for first time of the year with 1/4 tank of gas from fall and new seperator. No problems this year or in years past. (As I knock on my wood desk)
smokeonthewater
The writer of the article failed to understand the cycle that produces the water in the tank.... At night the temp goes down and the air in the tank contracts and air is drawn in... at the same time the air in the tank is not able to hold as much moisture as it did at a higher temp so condensation occurs. The next day as temps rise the air in the tank expands and (slightly drier) air is pushed out the vent. The next night the cycle continues. If it gets say 5 drops per night for 6 months then what's that come to?
jeeperman
From the article:
Research produced the following values for the maximum amount of liquid water in air at the following temperatures:
30C/86F 30 grams/cubic meter
20C/50F 17 grams/cubic meter
10C/13F 9 grams/cubic meter
I stopped reading at this point because:
20C=68F
10C=50F
If his research can't convert temperatures properly. I do not put much faith in it.:facepalm:
So what do you think 10C and 20C should be???
sublauxation
With some rough math it's about 450 average drops per fl oz, give or take 100. 15-20 drops per ML, and 29 ml per oz
wifisher
Just as it says in my first post. Twenty degrees celcius is equal to sixty eight degrees fahrenheit. Ten degrees celcius is equal to fifty degrees fahrenheit.
It is not what I think it should be, it is what it is accepted to be by the entire scientific community.
emilsr
I say store full....because gas isn't likely to be cheaper in the spring. :cool:
dingbat
How often do you refill the tank? Any excess moisture would be absorbed by the new "drier" gas you put into the tank and the answer would be little to none.
I keep my tanks 1/2 empty unless I need the extra fuel just for that reason.
lkbum
I think smokeonthewater has it correct...
here's a photo of gas where the ethanol has become saturated and fallen out. I keep my tanks full.
smokeonthewater
During long term storage???????????????? nobody fills the tank regularly during long term storage which is what this whole debate is about......:facepalm:
Now during the summer I struggle to keep it over 1/4.. If I can afford more gas then I go boating more :D
HT32BSX115
I always store my things with a full tank..... never had a problem with water in the tank....
That's good. I own a 1947 Stinson 108-2 Station Wagon. (that's an airplane for those that are aviation challenged) It has 22 gallon fuel tanks (1 in each wing....40 total usable)
I have owned it since 1981 (that's 30 years for those that are math challenged)
I've NEVER consistently stored it with full tanks. I've NEVER drained water from either tank.
My 1987 Four Winns Liberator has a 44 gallon tank. It was NEVER consistently stored with a full tank(I store it with about 1/4 tank) I removed the tank expecting to find water, when I bought it from my brother(who bought it new) about 6 years ago.
There was no evidence of water.
What should I conclude?
lkbum
Where is your boat located? In the south (Atlanta for me), the air reaches it's dew point virtually every night (at least in the summer). And in the summer, day night max/min temperatures are 40F (or so) apart which makes the thermal syphoning smokeonthewater pointed out significant. A possible conclusion you could draw would be that location is important when considering environmental effects. OT- Are you a C-17 pilot?
smokeonthewater
that you live in the north and have relatively low humidity and low temps
jeeperman
My bad, I read it wrong, sorry.
Home Cookin'
one important point that this discussion seems to overlook--the ethanol poisoning occurs with gas that isn't turned over. It takes 30 days or more to start getting funky, which is why it isn't a problem in most cars. During the boating season, those who use the boats a lot, adding fresh gas, burning gas, don't have the problems like the ones who get out once a month or only for short trips.
The discussion is good, but too anecdotal, with no consistent "control" to get too scientific about.
