Ignition module screws
Jon1229
does anyone know what screw size and thread is used to fasten the ignition module on a 2001 3.0 mercruiser? The exact screw has been discontinued and i couldn’t find specs to find a comparable one. I dropped one into the hull of the boat and searched for a long time with no luck. Thanks!
AShipShow
Screw might be stainless, but they are still usually slightly magnetic. Have you tried probing around the bilge with a strong magnet?
Jon1229
I haven’t tried that yet, I’ll give it a try. In the meantime if anyone knows a screw that will work let me know incase I still don’t find it
NHGuy
Take out the remaining one and go match it up at the hardware store. It's probably SAE, might be brass size 8 or 10 I'd guess.
alldodge
Don't know but it should be metric. The distributor cap screws are M3x5, think those are probably the same size, but maybe longer
Take the one you have to a hardware store and find a nut the screw will go into, then you have the size. If you do find out let us know, so others can find out
poconojoe
I just did this on my 4.3 Mercruiser and have two spares. I checked and they are definitely 10-32". Now I don't know for sure if your 3.0 has the same screws, so it's best to do as others have said. Bring the one you have to a hardware store.
Fun Times
Not having your serial number to confirm... I do believe you'll be looking for ACDelco part number 10469668 which is their bolts for the EST design module that should be the same as Mercruiser's part number 10-811638 only described as an Screw, cap, Hexagon Head... O'reilly auto parts may carry them too if so.
http://parts-catalog.acdelco.com/catalog/stock_check.php
https://www.oreillyauto.com/detail/...8/5744541/2006/dodge/charger?q=10469668&pos=0
Ignition Control Module Bolt
Part Number: 10469668
Product Notes:
All; VIN: K*
Per Vehicle: 2; Years: 1988-1995
http://www.mercruiserparts.com/bam/subassembly/30905/4893/90
https://www.asap-partsonline.com/rfq/brunswick-corporation/5305016430587/10-811638/
http://www.parttarget.com/5305-01-6...searchoption=sku&originalsearchtext=10-811638
https://www.justnsnparts.com/rfq.aspx?id=10-811638&mfr=brunswick-corporation&nsn=5305016430587
