Re: How to install a SMARTCRAFT system
Does anyone know what voltage readings I should get at the guage plug end? I plugged a 1 resistor harness to the can plug at the motor and plugged that into a 4 way junction box. I plugged a resistor into one of the junction box outlets and a weather cap into another. I plugged the guage harness into the last outlet and the ground wire to the electrical panel ground. I plugged in the system monitor guage and turned the ignition key and nothing happened. I checked the voltage at the guage plug and one of the pins has 12 volts. Is it the guage?
