Re: How to install a SMARTCRAFT system
Peter,
I don't know if you still answer questions regarding this topic, but if you do i would be grateful if you could provide me with some advise.
I recently bought a 2000 Mercury Optimax 225 (Serial# OT164859). Motor is still to be mounted to the boat.
With the motor came the following new items, which were never used with this engine:
79-859020-1 speed gauge
79-859019 tach gauge
820386A67 speed gauge harness
820386A68 tach gauge harness
881171A14 remote control
And an older type remote control (probably the one that came with the motor in 2000) No readable serial#
Connector on the new Remote control:
Connecting-diagram provided with the SC-gauges:
According to the diagram provided with the SC gauges, the SC gauges are only hooked up to the key switch harness. The connector on the tach gauge harness only fits the old (worn-out) remote control. A small round rubbery connector. Only one lead (gray) is goning to the SC gauges.
The connector on the new RC is square (see picture). From the remote control a thick harness hooks up in the motor by means of 14 to 8 pole adapter.
Having read al the info regarding the hooking up of SC-gauges in this topic i cannot image that is only a question of hooking up the SC-gauges to the key switch harness to have everything working. There must be more to it.
In your opinion, is it possile to get things going and what would it take. I think i will be needing a lot more hardware (harness(es); junction box(es) etc.) to make everything work.
I would be very thankfull if you could help me out.
Grtz.
Paul
