Re: How to install a SMARTCRAFT system
Answers are in RED
Pic #1. The trim sensor... What is it? Digital or Analog?
Let me look at mine at home, yours is different than on my 150, but the key will be the wiring!
Pic #2. The trim sensor wires. Look to be yellow, blue, & black. They are not plugged into anything nor can I find anyplace to plug them.
Well, that would be an issue, lol. Again let me look at mine and I will let you know if it is analog/ digital.
Pic #3. My finger is pointing to the plug that my Smartcraft cable is plugged into. To the left is a 3 conductor plug (The manual lists the 3 conductor plug as Boat Harness - Oil, Fuel, Speedo. Looks to come off the plug that the Smartcraft cable is plugged into and then plugs to something else... Funny thing is that on my port motor it was unplugged). Further to the left is a 8 conductor plug that the manual lists as SC5000 Data Harness. The 3 conductor speaks for itself... But is the SC5000 Data Harness something I should have hooked up? Or is for shop-type usage? Or even something else?
It is "fuel, oil, PADDLEWHEEL" not speedo, that is for connecting your fuel tank(s) , your remote oil tank (s) and the paddle wheel sensor if you have one. You should only have ONE connected between the two motors as far as I know. The harness should have 2 fuel tank connections and 2 oil tank connections. SC5000 harness? that should just be a can bus harness?? SC5000 is a display panel, just uses the normal harnesses. I would not worry about it.
Do you have your fuel tanks working on the smartcraft ???
