joewithaboat
- Jul 3, 2011
- 1,172
Re: Here We Go: My 383 Stroker Winter Project
Did you try setting them while running at operating temp?
double check for any interference...valve cover, retainer to rocker, also look really good for small exhaust leaks
id pull the plugs on that side to and make sure they look ok, just to rule out something bouncing around in the cylinder.
Hard to tell from listening over the computer.
Roller rockers will not be quiet, especially under tin covers. But is does sound louder on the even side.
Are the locks visibly all the same depth at least respectively on the 4 int and 4 exhaust on that side.
