greg82255
- Oct 26, 2009
- 781
Re: Here We Go: My 383 Stroker Winter Project
Thanks Tim. It looks like Eddie Marine and IMCO Powerflow are at about the same price, which makes sense if they put out about the same power. On CP Performance it looks like the CMI Headers with a satin finish are only 200 more than the Powerflow system ($1995 vs $1799). If I'm going to spend $1799 I'll probably just go for $200 more and buy the headers - they look too good to pass up. I'll probably keep this engine even if I don't keep the boat so I'm willing to put some more $ into it. I just have to make a decision at this point, and it's getting close to boating season so it needs to be quick.
I used to get 52mph by GPS on a good day with the 350. I was hoping for 70 when I'm all done but I'd be pretty happy with 65. I think 5000 rpm is probably a good bet for the alpha - although Tim has mentioned spinning his as high as 6500. I see you have a 1985 Chris Craft - are you running an Alpha gen 1 or gen 2 behind your 383? I would assume gen 1 unless it was changed out. How has it handled the extra power?
of the manifolds, imco powerflows make the most, eddy marine's are close to a copy of the imcos and make a little less. stainless marine are on par with the emi's, the long tube headers a bit more than the imcos but only at higher rpms. I don't remember the specific numbers for the comparison or even if he told me exact numbers. If buying new, the imcos were enough better to be worth the coin, the headers weren't enough better to spend the extra. they were all run on a 383 with about 10:1 compression, iron heads, single plane intake and around 400-425 horsepower. I wound up with a set of powerflows. new manifolds I found on craigslist for 600, used risers off ebay for 200. They run great and have held up well. stainless headers sometimes crack and are a bear to repair or so they tell me. and they didn't make a lot more power on the dyno according to the man...
btw. project looks like it's coming together well!
Greg: How fast were you before this build?
I gained 18-19 MPH gps. But my comp cams xtreme Marine 262 poops out (floats valves) at exactly 5000rpm. Which might actually be safer for myself AND my Alpha. Although Ive heard of people spining them alot higher.
