Heeeelp Evinrude 140 again - paging 2KBoat or Evinrude aces
Neil
Re: Heeeelp Evinrude 140 again - paging 2KBoat or Evinrude aces
2KBoat,<br /><br />the_griffs@yahoo.com for tha data please.<br /><br />Regarding fuel pipes, good idea. I have been through all these previously and all seems OK. VRO is not used.<br /><br />NG
93bronco
Ensign
if the address is correct i sent the info 2 times to be sure let me know thanx.<br /><br />as for the air re-circulation the last place i had it worked on crimped one almost closed and didnt even put the hose back on. that possibably aided in failure
Neil
Guys,<br /><br />Just to let you know the saga is still ongoing. Boat performance is still the same and I can't source jets here. <br /><br />2KBOAT, I didn't receive any information from you via email. Would you try again please.<br /><br />I can get jets via email if I know what to order.<br /><br />Thanks<br /><br />NG
Neil
Is there anyway I can reduce the size of this post?
93bronco
Ensign
you can start a new post and put this in as a reference.<br />be moving somethings around, will have to locate 87 parts manual.<br />will post the jet sizes here.
Dhadley
87 140 --<br />Idle air bleed (lower or one on the bottom of the two air bleed jets)= <br />28 with 397907 or 397908 stamped on the cover plate. Or 45 with 431883 stamped on the cover plate.<br /><br />Intermediate or mid range air bleed jet (upper of the two air bleed jets)=<br />16 with 397908 stamped on the cover plate. Or 20 with 397907 stamped on the cover plate. Or 32 with 431883 stamped on the cover plate.<br /><br />The high speed jet (in the bowl)=<br />59D (not C) with 431883 stamped on the cover plate. Or 61D (not C) with 397907 or 397908 stamped on the cover plate.<br /><br />Again -- a word of caution, DO NOT RUN THE MOTOR WITH THE AIRBOX COVER OFF!!
Neil
Dhadley,<br /><br />Thanks for this. <br /><br />2 questions, 1 stupid, where/what is the coverplate, are you referring to the carbs?<br /><br />Do you know how I could get these jets mailed to Oman?<br /><br />NG
93bronco
Ensign
thanx dhadley for answering this.<br /><br />-<br />any way the cover plate is the side plate on carb body with 2 screws. newer carbs use a sticker, but the older years were stamped into the plate.
