Re: Heeeelp Evinrude 140 again - paging 2KBoat or Evinrude aces
When you run your motor under a load, hit the primer (choke) to check for lean/rich conditions. If the motor gains rpm and then drops off it is too lean at the rpm you are running. If it does nothing for a split second, and then falls off it is OK. If it falls off instantly its running slightly to the rich side. Personally thats where I like mine. Not rich enough to blubber but right on the edge.<br /><br />Thanks for the updates.
