Re: Heeeelp Evinrude 140 again - paging 2KBoat or Evinrude aces
Dear NGRIFF1,<br /><br />My Evinrude V4 140hp 1990 used to have a problem of intermittent power loss and die at idle. I cleaned the carb, not improved. I changed the fuel pump using a non-VRO type and used premix gas, idle great, power loss problem improved but not disappeared. I changed the fuel filter to a larger one ( a higher flow ), the power loss problem was almost disappeared ( only occasionally at WOT ). I then rechecked the carburetor and found that one of the float was set too low, I adjusted the float and the problem had gone. I also found that the carburetor's gaskets were hard and stiff with some gas leak so I changed all. My motor runs great now.<br /><br />I think our motors are old now and many parts are nearly come to an end of their lifes and may help contribute to the same symptom. As in my case, if the fuel pump is strong, minor improper adjustment of the float together with a partially clogged fuel filter may not cause any symptom.<br /><br />Running the motor with carb cover off make it run lean. Most of motor will not run good or reach WOT with that cover off. If your motor run better with carb cover off, may be one or two carbs are running too rich or flooded when carb cover is on. May be due to the high setting of the float or defective needle / seat. Also check for the fuel hoses inside the carb cover they may be kinked or pinched by the cover.<br /><br />I'm a doctor not an expert. Just trying to help diagnose your problem.<br /><br />Good luck.
