I last posted in June (Joe Reeves helped with some advice) when my 1989 140 V4 looper shed a piston ring. I took advice and had a complete rebuild. A rebore and oversize piston, new rings throughout and a complete set of bearings. I am living in Oman and the no. of mechanics available is limited but the mechanical work seems good.<br /><br />Now I am having trouble with performance and the marina that rebuilt is struggling to locate the problem.<br /><br />After rebuild and 1 hours running in tank, engine was refitted. At the first outing now power available when throttle andanced from idle. Max RPM about 2500 and boat lacked power. Marina mechanics looked at it, couoldn't find problem and decided to take the boat to their workshop. After playing they decided it needed bigger jets because of the rebore. I was sceptical as the loss of power was significant. I think it actually performed better on 3 cylinders.<br /><br />Anyway, workshop was confident and said that engine performed at 5k RPM with test prop.<br /><br />Last night I took delivery and tested again. Exactly the same.<br /><br />Once engine started it continually cut out as soon as I selected reverse to back off the trailer. I managed to back off with marginal power.<br /><br />As soon as I selected forward power the engine would die. I could select forward trawl speed but as soon as I advance the throttle the engine dies.<br />If I go from forward creep to full power as fast as I can I do acelerate forward but only to a max RPM of 2500 but the engine sounds lumpy. If I go from idle to full power slowly then the engine dies.<br /><br />At fast idle the engine sounds smooth and quiet. I have been up to 3000 rpm and no problems with missfire.<br /><br />The engine seems to behave as if the propeller is snagged in a net. Forward and backwards have the same effect.<br /><br />Mechanics are coming out again tomorrow but I don't have a lot of faith at the moment.<br /><br />When the engine was rebuilt the mechanics changed the powerpack as they said it had no power out of the water.<br /><br />Anyone have any ideas what it could be so I can double check what is going on?<br /><br />Help appreciated as always.
