Daniel1947
Thread starter- Joined
- Sep 22, 2010
- 267
A short greeting to all Forum members which includes a "late" Merry Christmas and Happy New Year. As always, I appreciate all the intelligent input. Holiday's and weather of course put the boat on the back burner, however the cap is finally in place on the hull. Have about 10 screws on both sides in place and it seems everything will line up OK.
During the demo, I had to cut away a little too much material to separate the cap from and hull at the transom. I have built up the area and replaced /reformed some of the fiberglass in that area. I will clean up the ragged edges as I move forward. However, there is a small gap where the cap sits over the transom.
As can be seen in the following photos, the gap is actually less than 1/8" wide.
My question is: Should I use Peanut Butter, 3M 4200, 3M 5200 or 3M Marine Grade Silicone to fill in the gap.
If the consensus is Peanut Butter, would you go with Jif or Peter Pan, smooth or crunchy? :laugh:
Looking forward to all the great information that is usually volunteered her on the Forum,
Thanks again to all.
