Funny "TLC needed" boat ads on Craigslist.
jbcurt00
Re: Funny "TLC needed" boat ads on Craigslist.
To be clear:
NOT ME!
64osby
TRI-HULL w/ TILT TRAILER
14-1/2 ft fiberglass Renken tri-hull bow-rider w/ tilt trailer. The 1973 boat needs some work. There are no leaks or problems with the hull or major problems, except for a soft transom. The front cutting edge needs reinforced (it is worn but doesn't leak.) Carpet is old but still usable; but should be replaced. The boat will need new seats. The transom will need to be repaired or at least reinforced. The trailer (also registered as a 1973 model) is a heavy-duty tilt trailer. The trailer needs a jack; trailer needs paint in several spots but is otherwise sound. Trailer does have spare wheel and tire. The trailer alone is probably worth the asking price of $400. Titles to both boat and trailer. Boat is registered until 2014. NO MOTOR. Tires seem serviceable (I drove it to WV from VA) but they are full of dry-rot and will have to be replaced soon. I will put new lights on so it can be driven on the highways. Trailer without boat is $450; save money and buy both for $400. Will consider trade for aluminum flat-bottom jon boat with a wide beam . . . I can pay cash difference if any. This would make a nice boat for a small family, stable, strong, relatively shallow draft, roomy inside yet not too large. The wooden framework on the top, and plywood over the front, are supports for tarps to keep water and dirt out so we can work on it.
GA_Boater
Interesting ad. Trailer (sounds like it needs work) for $450, Take my trash boat too and I'll knock $50 off. Aw, the "hardtop" is only a work cover, darn.
64osby
^^^That trailer looks road ready.
GA_Boater
Finally - A boat for sale and the trailer alone isn't worth the asking price. LOL Wait - He's keeping the trailer, boat/motor only! :facepalm:
tomhath
Master Chief Petty Officer
Ahhh, but the motor is a 25 y/o non-running Merc that appears to have spent it's entire life in salt water...never mind.:faint2:
ezmobee
That Merc is a good bit older than '88 methinks ;)
GA_Boater
Guy's you should see this thing!!! Pictures didn't do it justice!!!
I'll have you all over for a beer... One at a time please...
I understand why only one at a time, It's so full of stuff (junk). Does it come with cold beer, RJB?
RogersJetboat454
what do you think?? $600 aluminum prop?????
aluminum right hand prop
I think....he will be sitting on this prop for a long time
bob
Actually... he aint lying about the cost of them new;
http://www.google.com/url?sa=t&rct=...3IC4Ag&usg=AFQjCNGdAJzW7JLqnO38GRmI2G1cdG4abg
http://www.google.com/url?sa=t&rct=...3IC4Ag&usg=AFQjCNH3tye7eJYM0psfrOzBpJt3VyRGow
http://www.google.com/url?sa=t&rct=...3IC4Ag&usg=AFQjCNEzXr5dtllgxnp1NTOBetHLQoMsIg
It's an O.E. manufactured, high thrust elephant eared prop specifically for the Bravo 2, that he probably bought at a brick and mortar marina. Seems like he's actually giving a good deal on it, if it is what he says it is.
TilliamWe
Banned
Nope, Bravo 2 props are EXPENSIVE! That one appears to be decent. He could sit on it for awhile, but only because Bravo 2s have really fallen out of favor, due to the Bravo 3.
QC
Yeah I am seeing Bravo 2 Aluminums going for almost $400 on eBay. That's where he should list it. More chance of someone finding it.
mr300z87
It is true that Bravo 2 Props are expensive. I scored a nice used Bravo 2 prop on ebay for $75.00 and was happy with that. New they start at $450 for aluminum. ^^^^ this guy is out of his mind. BTW have you seen the price of Bravo 3 props :eek:
TilliamWe
Banned
... BTW have you seen the price of Bravo 3 props :eek:
Yeah, if you look long enough on Ebay you can get a used set for under $600. No sane individual pays Mercruiser Dealer retail cost for them.
GA_Boater
Fishin' Shack update. New bidder, new bidder - went $610. Not to be out done first bidder came back with a $611 up bid. 2 days 22 hours to go on this classic.
And a new entry from CL.
have something no one else has this boat is in fair condition the guy said the engine runs it just needs a lower unit has a good trailor with fair tires great project and fixir upper one of a kind call 256-6XX-XXXX cash only may take trades on 4x4 atv or truck
Nice lil speed boat. :rofl:
007 james bond style speed boat with 50hp mercury
