Funny "TLC needed" boat ads on Craigslist.
motorwinder
Re: Funny "TLC needed" boat ads on Craigslist.
Poor guy, someone should buy this boat. Can't even afford anymore gas to make sure it runs. I would trust him. Sounds like a great boat for Crocodile Dundee! 22.2 ft. SPORTCRAFT
crabby captain john
Check the trailer -- looks like it will never track correct, may take 2 or 3 lanes if it ever moves. At $495 he may be 1500 too high!
Looking at the first picture I don't see any tires. Appears to be bare rims with the trailer held up by a concrete block. At $495 the guy is about $1000 too high.
Silly Seville
A Big one and a good one...
1970 Mercruiser Lower Unit
1970 Mercruiser Lower Unit. 140 HP COMPLETE. This is the Big one and the good one. $500.00 216-xxx-xxxx
I didn't know they made a bigger and gooder one 40 years ago. I also didn't know that the outdrive had 140 horsepower. That really must be a big arse outdrive. But will it perform better than my smaller and junkier Alpha 1? :rolleyes:
still afloat
$1000 Force motor "only needs one cylinder replaced"
outboard engine with trim 1993 force 150
outboard engine with trim 1993 force 150 - $1000 (Blackwood, NJ)
image 1image 2image 3image 4image 5image 6image 7image 8
1993 Force 150 w/trim
150hp
Controls not included
Engine needs at least one cylinder replaced and gasket
Lower unit and trim fine
Used second emergency prop included
Local Pickup only
Please contact Rob at 609-315-7989
Thank You
Silly Seville
Hey...come pay me $100 for the privilege of taking my trash to the dump.
cheap fiberglass boat, 60s ferbglas 16'
Just want to get her outta the yard. Title in hand, don't have the time for the refurbish.
Silly Seville
Finally...the Titanic goes up for sale! Only $400. Bailing wire included! Horses are extra.
Boat, motor, trailer
1976 15' trihull Boat. Basket case. Junk title. 1978 Evinrude 70 HP motor.
Hasn't been started in 10 years. Steel boat trailer. Tires are old and dry rotted.
reelfishin
A buddy of mine had that same model boat brand new, but with a big block, it needed every last bit of power the worked up big block made, I think top speed on his was about 90mph in light chop. I would think that its pretty under powered with that small block in it if its speed your after.
With that said, which of those toys do you think is the most expensive?
All in all that's probably not a bad deal if someone is into that type of boat and is looking for a project.
crabby captain john
Most expensive is the one between the boat and bike... no question!
