- Mar 8, 2009
- 44,666
Need Help with cutting stringers
Been making progress and now need to determine what is the best way to fit new transom. Still need to do a lot more grinding before we start the install.
Current process is we made a cardboard template and cut wood. Was thinking of cutting using the black line perpendicular to the transom. Stringer is 1 inch plywood and glass. Slide the pieces of the transom in one at a time in stages.
Mix up some resin and Chopped up CSM making peanut butter consistency. Resin coat both sides and edges of first piece and slide in place.
Add layer of 1708 to first piece and wet down getting bubbles out.
Resin coat inside and edges of second piece and install on first piece. Then install clamps and let setup.
So is plan OK, and what should I change?
Also what is best way to cut stringers and replace?
