coolguy147
- Jul 14, 2008
- 2,817
Re: evinrude 10hp qd-23
ya im surprised to of what happened. the washer i used to keep the bolts inplace were bending in and my thing was moving a little and the bolts bent a little. i hammered it with a wood bloack in place then repeated until it came off. well the thing scared the crap out of me cause i thought i broke another bolt cause there was a very loud pop when that flywheel comes off. that idea using the belts and plummers wrench i found very very helpful
ya the long screw on one of the coils i took off i guess was it so 2moro ill try to take a look at a little. my kill switch works fine and the wires look good i mean am i able to detach it some how and nothing go wrong. i would like to still keep it incase my throttle cable breaks and i have to find a new way to turn it off. and not sure if i can take a picture seeing as that no camera i mean i wouldve shown u my motor a long time ago. and when link and syncing i should put so the butterfly starts to open when the roller is on the little line in which the roller rolls on? and if u read my previuos posts i got a feeler guage and a torque wrench
so should i reinstall alll the new points coils and condensores then tkae the " mag plate i believe its called " off and finish up with the spark plug wires under there? then adjust and the points
the link and sync is done with the mag plate on or off and specify hwo tis done
