infideltarget
Master Chief Petty Officer
- Aug 30, 2010
- 802
Re: Engine blew up today.
Preach it brother!
I must say folks are down on automotive engines. :facepalm:I dropped a 1996 gmc truck engine in my Baylinner two years ago. Pulls skiers fine and tubes with ease. As far as the numbers go same block, crank, heads, and pistons. Cams did have a different casting number. I just used the truck cam. I could not be happier. 200 dollar engine with 50 hours boating no smoke and stays full of oil. I did use the automotive gaskets from northern to put it back together.This is a fresh water boat with steel freeze plugs just like the ones in the original block.
Starters carburetors and ignition should stay marine after that use what you want. Lot of guys overpricing engines just by saying it goes in a boat.
Preach it brother!
