infideltarget
Master Chief Petty Officer
- Aug 30, 2010
- 802
Re: Engine blew up today.
I stand behind what I said about this 100%. The original H.O. set up was founded by taking a 351w marine cam straight off the shelf and putting it in a 302 block. Further development was necessary to bring it to market, but the grind was, and is, based on a marine 351w application. Check Ford history if you doubt it. I know very well what else was changed, as I have owned / restored more than 15 'Stangs from '67 to '93, and still own two Foxes. We can continue this in PMs or over at StangNet if you want.
There are plenty of automotive engines out there in boats running just fine right now. Are they optimal? Prolly not. Are they the ideal swap? Prolly not. Will they work and get you back on the water? You betcha'. Your budget and what performance / longevity you are willing to sacrifice will be the deciding factors.
they used the windsor firing order. lift/duration was different from any factory 351w grind. they also changed the heads and went to a speed density FI setup.
