can't plane after engine swap. does reach 5000 rpm's
QC
Re: can't plane after engine swap. does reach 5000 rpm's
Actually I was thinking a load of weeds too, but this happened multiple times and he changed props. Bondo suggested leaving the trailer in the parking lot in the 2nd reply :D
Ayuh,.... 'n it's still a viable answer, Sixty posts later....... ;) :D
Alwhite00
Master Chief Petty Officer
Isn't the Alpha only good for 300hp? - Be careful with the holeshots.
LK
onebadbusa
Thanks guys. Maybe I should have unhooked the trailer before trying to plane out. Can't really believe it has 325 HP with the original 2 barrel on it. I did consider trying a third even larger prop because of the added HP. It isn't a fake thread and I am real. I have ne explination how it runs now verses last year.
QC
All good, and you're right, the two barrel is not putting out 325. You replaced the long block I suspect. I have never understood how they can sell a _____ hp as a long block. I know why they do it, but there is no way for them to determine what the horsepower will be without a specific fuel system.
