Goldie627
Thread starter- Joined
- Oct 28, 2013
- 1,010
I agree Rick, my compression is not perfect but then again its not bad enough to worry about it.I wouldn't bother worrying about the compression. It is in 'fine and dandy' zone. With that engine sitting for a few years, it will do it most good to run it. Running it will free things up and clean things out. You aren't going to re-ring it with numbers like that, so why bother with more tests?
Im looking at a carb rebuild kit from mikes
http://www.carburetor-parts.com/Mercarb-Carburetor-Kit_p_3483.html
a few reasons why im thinking to rebuild..
1.) spark plugs are etremely dark after just 15 minutes of running
2.) idle dosent return consistenly, have to press down on linkage, i think there is an internal return spring
3.) not sure about my choke gonna look at it
4.) previous owners removed the carb fuel filter and spring and did not replace it just left it out
5.) recommended by rick :watermelon:
