sprintst
- Apr 18, 2009
- 2,066
Re: 77 Starcraft Holiday 18 i/o - rebuild with pics galore
Just a knot on the head from a fish bonker works too
I'm hoping the time thing works as well. Today was a good start though as I'm at the point where I can pull the transom after undoing a couple more bolts. It took about 4 hours to get all the junk off the transom, transducer, battery isolator, rear top cap supports, etc.
I'll see if I can dig up the wiring thread I was following many months ago. The dude just sent off his wiring harness and got a custom made one that was perfect and exactly to length, heat shrink wrapped connectors, heavy guage, color coded corectly, etc. Otherwise I may go with what I have for now and do a do over later.
Hey sprintst,
Just a couple notes, If some one says your speedo doesn't work just hook the bilge to a respirator that way you don't even have to get your hands wet.
I hope that you get everything done it the time frame you have planned.
If you can get it rewired for less then it would cost you for the wire that's the way to go. But if not it's really not that hard to do yourself.
Keep it rolling.
Bob
