Stern deck support cut. Having an existing template to work with is SO NICE. Really makes for a quick job. This'll be epoxied.
More epoxy. These are the bow deck support pieces, getting a second coat. Instrument panel has 6 holes in it for the gauges. We're not sure how high to make the panel (because the gauges are like 6" long. So we'll continue shaving off material until we can't go any further.
New steering cable arrived today (black). We're going to have (hopefully) just enough to make it to the steering wheel up front.
Mocking up seat box heights / width / length to fit in the boat. Home depot medium size boxes worked well. Decided on the seat boxes being 17 3/4" wide, 12 3/8" tall, 15" long. There'll be 4 of them, and we're still working on how to connect them to the deck.
Thinking something like this:
Hammered into the top of the countersunk deck (so it sits flush), and HEAVILY epoxied. Should be enough to keep it from pulling out, and would allow us to move the seat boxes for when we're hunting out of it.
Console finally cut flush and sanded down and gaps filled with epoxy.
Dog house pieces and seat box pieces curing in the sun. Each coat of epoxy took about 1 hour to cure. We applied the second coat as soon as your finger print wasn't being left in the epoxy. Some sides of this exterior ply REALLY soak up the epoxy.
If you've applied two coats, and the wood still looks "woody" and not glossy from the amine blush, does that mean you still need more?
-John
