Re: 73 15' Silverline Comoro transom and stringer replace
I don't think it is a separation it appears the previous owner trimed the outer skin and removed bad wood then used Seacast or similiar to fill the gap. I will make a paper pattern of the transom before I cut anything.
Aren't you removing the entire top cap? If so, the splashwell and Transom cap will come off with it, exposing the transom for repair.
This pic clearly shows the separation of the splashwell and the stern of the hull.
You may need to use the oscillating tool to cut away some of the "GOOP" used to fill the gap but that's about it. Some MFG also "GOOPED" the seam between the top cap and the hull. If so, you'll need the tool to cut that away as well.
