No Title
Quick update...I have my carpet installed and the plywood backing to the hull lip glued and curing. I should be ready to bring the cap back in the garage now. Once I get it back in I will have some work to do repairing a section I had to cut out of the splashwell to get the cap off at the beginning of the project. I think the carpet went well, I used indoor/outdoor adhesive for the deck and spray contact cement for the sides. The deck was easy, I loose laid it in place, pulled half of the carpet back, spread the glue with a 1/8" trowel then laid it back down. I took a rolling pin and rolled out the carpet. Once the first side was done I repeated the process for the other side. I chose to use contact cement for the side walls because I didnt want the carpet to droop while it dried. I just sprayed both surfaces, waited a couple of minutes then slowly worked my way from the deck to the top of the side wall. It was a little more challenging because you dont have much (if any) room for error once you mate the two surfaces. Here is a pic of the finished product minus clean-up. I decided to leave the area under the splashwell un-carpeted (will paint) so that if gas/oil spills Im not having to deal with cleaning the carpet.
