Pinter Boat
- Jun 5, 2016
- 19
I have a 2020 MFS 50. How do you release the shift linkage to drop the lower unit?
Thank you. Does the threaded coupler adjust how it shifts, i.e. do I have to tighten it back to the exact same position in order to get it to shift properly?Yes. It has a threaded coupler. What is a 4S?
Thank you!That model should have the threaded coupler since its a 4S. Loosen jam nut with 10mm wrench while holding coupler.
