50 hp water pump replacement
Pinter Boat
I have a 2020 MFS 50. How do you release the shift linkage to drop the lower unit?
Sea Rider
Around the upper gear case there should be a round shift rod joint that holds the upper shift rod to the lower leg's cam rod by means of a spring pin, if so must push the spring pin out to release both vertical rods...
Happy Boating
Faztbullet
That model should have the threaded coupler since its a 4S. Loosen jam nut with 10mm wrench while holding coupler.
Pinter Boat
Yes. It has a threaded coupler. What is a 4S?
Thank you. Does the threaded coupler adjust how it shifts, i.e. do I have to tighten it back to the exact same position in order to get it to shift properly?
pvanv
Put the coupler back where it was... as closely as you can.
Sea Rider
I'd guess the threaded coupler is screwed till stops tight as you found it before being uscrewed. 4S (Four Stroke)...
Happy Boating
