Hello and thanks for taking the time to read this. I have been having trouble with my boat ever since i got it on the water 3 years ago. It is a 1989 17' Smoker Craft bow rider with a 130hp 3.0l Mercruiser and Alpha One outdrive the engine SN is OC529850. the previous owner did not winterize it on time and cracked the block but he ran it with no issues for a few years with JB weld on the crack. it started leaking again and the starter crapped out so he sold it to me real cheap. I let it sit a few years before messing with it. first thing I did was a brand new Carb since the fuel had gone bad and I fixed the crack again. It was still running bad so I brought it to a mechanic. he found the fuel screen on the carb full of sandy stuff so he rebuilt the carb and i cleaned out the tank and the fuel pump that was corroded inside. I also put a fuel water separator in it to filter the fuel. now the fuel is clean and it will run good for a while but after about a half hour of cruising at around 30mph it will get a few little barely noticeable pops. then It quickly gets worse backfiring, sputtering, and stalling out. It will start right up and idle but won't go much over idle. and the longer i let it sit the better it will run good for
Before I throw any more money at it I was looking for anybody's thoughts as to what it could be. I was thinking maybe the block is cracked inside letting water into the cylinder but the boat ran fine before i let it sit and i don't get water in the oil. Someone suggested that the distributor may not be advancing or something. I'm to the point of looking for a new motor but cant afford it now. any advice is greatly appreciated
Thanks
Thanks
