Ok guys, I need some assistance. I am a noob to I/O boats and I got my hands on one for dirt. I am mechaniclly inclined and can fix pretty much anything. I now have 2 boats one is a very basic 14' Tinny with a 9.5 Evinrude OB that I got running like a top. Not to my current project. '84 Mercruiser 2.5L 4 Cyl S/N 6719631. I have another thread going in the general boat questions about this 84 Sea sprite I accuired for a reasonable price. When I picked the boat up the PO and I had it on muffs and it turned over and fired briefly. I need to replace the lower shift cable it is kinked and the outdrive won't come out of gear, I get the boat home and proceed to begin cleaning up the PO's mess and she is trying to be a PIA!
I need some assistance the Admiral is begining to doubt the purchase and I am frustrated. I have ordered the Shift cable kit and a few other things that were in desperate need of replacing. What I have done so far:
1. Re-attached the upper control cables to the control unit and the engine
2. Cleaned the Carb
3. Pulled the plugs and cleaned/gapped them to 0.045 (tag on the Block says this is the correct gap)
4. Checked spark looks good
5. Pulled distrubutor cap and cleaned the contacts, the rotor arm and the points.
6. Cleaned and lubed battery cables (both ends)
After doing those I am still having issues getting it to fire up, any ideas of what else I can check? Help me out here I am about to start throwing wrenches and cussin' Which the Little admiral goes and tells the admiral about and I get yelled at.
Thanks guys I appreciate it
2. Cleaned the Carb
