Ops, if that wobbling is the crankshaft they you need to rebuild the engine I guess.Hello All,
Also, I took the flywheel cover off and noticed while running the timing wheel bolt looked to have a little wobble to it. The bolt isn't loose. I turned the engine off and grabbed the timing wheel and rocked it by hand and it had some play in it, which resulted in a knocking type noise like too much play. Does this sound like the upper bearing is bad? Is it possible to change that bearing without splitting the powerhead? It looks from the drawings i found online, that it is just a cap that screws on with the bearing inside it. Any other suggestions? i'm including a link to the youtube video i took for reference about me rocking the timing wheel.
Any help is appreciated!
https://youtu.be/-6a_REZ-8oA/
If you have been having water in the oil then I would suspect maybe some more bearings are bad and possible the cylinders
