ReelTime2016
Thread starter- Joined
- May 19, 2016
- 10
Hello All,
As a background, I bought a Pro-Line Stalker 180 a few weeks ago with the Johnson V4 with OIS ignition. First time I took the boat out it ran great, then abruptly stopped, then was hard to get running againt. I finally got it to start and long story short, my carbs were dirty. I took carbs apart and what appeared to be water was in the carbs. I cut the VRO line and low and behold... water in the oil tank.
Ordered carb rebuild kit, blocked VRO, premix gas engine runs great.. put it in the water this past weekend and notice a ticking noise coming from around the flywheel. It's not loud enough that you can hear it over the exhaust on the muffs, but it's there if you listen closely for it and it's fairly obvious when it's actually on the lake. The ticking does increase with engine revs. I used a screwdriver to listen and it is loudest at the back of the top starboard cylinder and then just under the flywheel.
I ran the engine last night in the dark to look for jumping spark but couldn't find anything. Just from where the noise is coming, to me it seems that top bearing may have overheated when the VRO was pumping water/oil sludge...
Also, I took the flywheel cover off and noticed while running the timing wheel bolt looked to have a little wobble to it. The bolt isn't loose. I turned the engine off and grabbed the timing wheel and rocked it by hand and it had some play in it, which resulted in a knocking type noise like too much play. Does this sound like the upper bearing is bad? Is it possible to change that bearing without splitting the powerhead? It looks from the drawings i found online, that it is just a cap that screws on with the bearing inside it. Any other suggestions? i'm including a link to the youtube video i took for reference about me rocking the timing wheel.
Any help is appreciated!
https://youtu.be/-6a_REZ-8oA/
