1999 Johnson V4 Looper Ticking
ReelTime2016
Hello All,
As a background, I bought a Pro-Line Stalker 180 a few weeks ago with the Johnson V4 with OIS ignition. First time I took the boat out it ran great, then abruptly stopped, then was hard to get running againt. I finally got it to start and long story short, my carbs were dirty. I took carbs apart and what appeared to be water was in the carbs. I cut the VRO line and low and behold... water in the oil tank.
Ordered carb rebuild kit, blocked VRO, premix gas engine runs great.. put it in the water this past weekend and notice a ticking noise coming from around the flywheel. It's not loud enough that you can hear it over the exhaust on the muffs, but it's there if you listen closely for it and it's fairly obvious when it's actually on the lake. The ticking does increase with engine revs. I used a screwdriver to listen and it is loudest at the back of the top starboard cylinder and then just under the flywheel.
I ran the engine last night in the dark to look for jumping spark but couldn't find anything. Just from where the noise is coming, to me it seems that top bearing may have overheated when the VRO was pumping water/oil sludge...
Also, I took the flywheel cover off and noticed while running the timing wheel bolt looked to have a little wobble to it. The bolt isn't loose. I turned the engine off and grabbed the timing wheel and rocked it by hand and it had some play in it, which resulted in a knocking type noise like too much play. Does this sound like the upper bearing is bad? Is it possible to change that bearing without splitting the powerhead? It looks from the drawings i found online, that it is just a cap that screws on with the bearing inside it. Any other suggestions? i'm including a link to the youtube video i took for reference about me rocking the timing wheel.
Any help is appreciated!
https://youtu.be/-6a_REZ-8oA/
Honorary Supreme Mariner
Water in the oil tank means it is time to do a compression test.----No point doing anything else now.
ReelTime2016
Ok I'll do that this afternoon. Was 125 lbs on all 4 cylinders when I bought it so I have an exact base line before the water issue
LastCall1983
https://youtu.be/L_tz-vDILKE Here is a link to the engine running.. it's not a loud tick, but it's definitely noticeable. I'll check compression when I get home and go from there. Alof of people say that the engines tick when VRO is removed.. and a lot of people say their engine has always had a tick in their Johnson engines.. I'm just not sure what's acceptable as a "normal" tick
I lost this login information.. not sure how it logged me in automatically now but anyway, I guess I have my old login back now.
ReelTime2016
Checked compression it's still good in all 4 cylinders. Identical to what it was when I bought it. Where to go from here? Timing wheel off, then check tomake sure flywheel bolts are all tight. Should the timing wheel be able to have play in it like in the video? It's bolted right to the crank correct? If it moves like that then the crank bearing is probably shot? Is the timing wheel bolt reverse thread or normal?
Bosunsmate
ive no idea on the timing thing, ive never had to deal with one but i dont expect anything to ever be lose on an outboard as itd rattle to death.
To check upper bearings i just grab the fywheel and make sure there is no play more than a hairbreadth in any direction.
Often itl be firm in one opposing direction and a hairbreadth in another-thats normal
ReelTime2016
If the timing wheel is directly connected to the fly wheel then I've def got too much play.. May be upper bearing
flyingscott
That is an OIS timing wheel that is NOT attached to the flywheel it is for checking the timing. Make sure that has not broke It has it's own key on the crank and it needs to be removed for the sensor removal is it tight try re-tightening the bolt. The flywheel is under another whole timing assembly on that motor.
ReelTime2016
Do you know if it's reverse thread or normal thread flyingscott? Do I need to worry about watching how it comes off out will it only go back on one way? Like I won't mess the timing up?
ReelTime2016
Ok, so i took the timing wheel off and the fllywheel cover and grabbed the crankshaft and it has the play in it like the timing wheel video did.. it makes a clink when i pull it due to the play just like the timing wheel did. I have a johnson 70 laying around and grabbed the drive shaft on it, it has 0 play compared to this one.. SO now my question is, since its a 99' do i just ride it out until it blows? it's not like SUPER sloppy play, but it's enough it makes that "clink" noise when i snatch it back and forth..
VIDEO: Https://youtu.be/YrNiqbalpu8
OR is there a simple upper bearing i can check on the upper outside of the powerhead and just replace it like on some of the other engines? I could tear the entire engine down if needed because i have another boat at the moment for back up through fishing season.. i just don't know where to go from here.. I stuck a dowel in the spark plug holes and on the down stroke gave the piston a good push, didn't have any play in any of the pistons.. it's just like the top of the crankshaft (upper bearing) is bad or worn and letting the crank move.. maybe it overheated with the VRO issue. Would that possibly mean my entire crank is trashed now too?
flyingscott
If it was mine I would rebuild it now riding it out could cause irreparable damage.
ondarvr
In and over heat situation when the motor stops, the bearing typically isn't the first casualty, normally you've done damage to pistons and rings, which may require a complete rebuild. Check the compression before making any further plans for fixing it.
oldboat1
Isn't there a bushing up there? Maybe you are feeling movement in a worn bushing, not crankshaft movement (maybe producing the timing wheel wobble.)
Bosunsmate
pull the old bearing out, inspect and replace, easy to remove, you dont need to split the crankcase. Post a pic of what you find.
your test of the big and wrist pin bearings indicates you may of gotten away with just failure of the bearing. Chin up
Bosunsmate
Actually whats your motors model number, not sure what it has as i cant find a 1999 180
Faztbullet
You have to spilt crankcase to access top bearing on a 60 degree......IMO go ahead and pull it apart and fix it,
The 180 would be the boat model.-----And yes you have to split the case to change the bearing.---All that bearing style locate on a dowel pin !
ReelTime2016
Yes it is the v4 60* 115 with Optical Ignition System. How difficult of a fix would this be if i just do the bearings? the pistons/wrist pins right now appear to not have too much play in them. No tick at all in the bottom half of the engine, just the top near the flywheel where the play is..
Truth is i don't care if it's perfect as long as i can get another couple of seasons out of it before I go to a newer boat
ReelTime2016
I have the shop manual by the way.. .i'll look in it and all. I built a chevy 383 stroker from a 350 block.. did the clearancing and assembly myself. everything in it was brand new.
It isn't the engine work that has me questionable, lol it'is all the stuff that goes on the outside of these motors.. all the linkages, etc. I guess i just take alot of pics and i should be ok.
