1995 115 timing?
aid1970
i have looked at the how to check the timing top secret file but how do you adjust it and what is the correct setting for this motor. its a E115TLEOR 90 deg. thanks in advance:)
aid1970
Re: 1995 115 timing?
Help Please someone must know :):):) i wanted to go out on my boat at the weekend:D
Setting the timing on that motor is a bit involved. I would recommend you purchase an OEM Service manual.
aid1970
Thanks Chris. i cant get my hands on a manual before the weekend and i am desperate to get out on the boat so if anyone has a copy of that page or pages or can tell me how it would be greatly apreciated:) i dont want to do any damage to the engine running it, because i had to fit a new flywheel and wanted to make sure i dont get detination:( any help would be great:)
hayuuga
Hi
Use a timing light. you have degrees stampt on the flywheel.
Factory timing on crossflows are 28? BTDC.
BUT I wouldnt recommend more than 24 maybe 25?.
higher can burn your pistons.
Disconnect carb linkage. You want to be able to give full "trottle" but the carbs have to stay closed.
If doing this out of water i recommend you to take of the prop. It can save your legs.
Connect timing light sensor at cyl #1. That is starboard upper.
connect water hose.
Start it up and give full power.
It wont rev to much, maybe 4000rpm.
adjust the timing stopper, in to decrease. out to increase timing.
good luck
David
aid1970
Thanks for that david i was sure somone would help me you are awesome i will do it in the morning and try her out. Is this a better way than the one in the top secret files off the key??.
Thanks
Adrian:):):)
Al-53
careful running a motor that high with no load..it can run away.....on muffs can be tricky....hope it works out for you...good luck
Al
aid1970
Thanks Al so would you say do it from the key like in the top secret section??
Adrian:)
Al-53
Well if u just changed the flywheel and made no other adjustments....I see no reason why the timing would change...then new one will go in same as the old one....its keyed on the shaft....so should be the same as the old....
now you did torgue it to specs right....and did it dry no anti sieze or grease..DRY....I dont know your torgue specs..but for some reason 140 foot pounds come to mind....dont quote me....but you do need to torgue it...
if the timeing was good before it should be fine now.....
Al
ezeke
100-105 foot pounds on crossflow V4 engines.
aid1970
thanks guys. i replaced the fly wheel due to the magnet being loose and i dont know if the last owner made any changes because when i got it it had new coils,plugs,cdi unit,fuel pump so just want to make sure its good before i do any damage.i got the motor none running.:)
thanks
Aid
emdsapmgr
Joe Reeves has a nice explanation on setting timing in an article found in the Top Secret file at the top of page 1 of this forum.
aid1970
yeh iv been looking at that does my engine have the quick start advance?? how will i know?
thanks
Dhadley
If your center magnet was loose then you are doing the right thing by checking the timing now. If the old magnet was off and they set the timing it may be off with a correctly placed center magnet. No matter how you set it initialy it needs to be verified under a load.
Don't forget to check the timing pointer to make sure it's placed correctly too.
emdsapmgr
Quickstart was only on those crossflow engines that had the vented flywheel-limited to the V6 line. In 1995, the only V4 engines with quickstart were the 60 degree loopers.
