1990 Bayliner 2651 resto
Drivewayboater2
Update 6-29
another project that needed attention. The aft locker was toast. I removed that a couple years ago. After removing the rotted wood i made a template out of cardboard. So today I decided to tackle this and use polyester instead of epoxy. Learning curve here. Here’s the locker empty with the old wood shelf removed.
after several test fits I got the new wood fitted
first time using polyester resin… I’m a epoxy guy…. This was stinky and wow work time was speedy. Happy with the results tho.
Both sides of the locker floor treated with resin and a layer of csm.
getting ready to trim the excess cloth off.
final look after trimming excess.
came out nice.. first time using polyester was interesting
hope I can install the shelf tomorrow…
progress is progress. Plugging away at it.
Drivewayboater2
Maybe…it was incredible how fast it cured..I wanted my first attempt on something less critical to the structure of the boat. happy with the results.
Drivewayboater2
7-5 More progress. Finished replacing the after locker. Used polyester resin in 90 temps. Stuff was kicking off in like 10 minutes. 🤣
Made small batches about 8 oz at a time. dry fit the board. tabbed in with 6 in wide csm. Very happy with how it came out. A little paint and she will look purdy.
63FAC911-B93A-4FF3-9331-0FDC487146BC.jpeg 2FC43E8E-C85F-4C9E-AC89-A0CEDC1C560B.jpeg
Drivewayboater2
7-6 very hot temps today. 96+…
got out early and put he second coat of paint in the aft locker.
also put a layer of 1700 on the fuel tank shelf. The tank may get installed tomorrow.
Drivewayboater2
Also epoxied up the old holes for trim tabs and fish finder. While I was at it I drilled out the outdrive holes ( a smidge over sized) and epoxied those up as well. Ya know the little details. Getting it done!
Drivewayboater2
Update 7-21
fuel tank is in.
using plastic baseboard on each corner with pl marine adhesive. Started on the starboard side front corner. Using wood splitting wedges to help keep the tank snug while the adhesive is curing.
then starboard side aft.
fabricated solid piece of linear fir to cap the entire aft bulkhead
it will fit like this once all corners are complete. This will be glassed in with 1700. Should help support the entire aft end of the tank🤞🏻.
question. There wasn’t ANYTHING previously holding the tank down. Do I need to fabricate aluminum pieces to secure the tank to the stringers? Need to know before I start putting the floor in he aft cabin down. Any thoughts?
kcassells
As I understand it there should be not tank to contact surface and neoprene being the material to use as the buffer. Something to do with corrosion. I would suggest some form of support for the top of the tank. JMHO
Drivewayboater2
neoprene was used under the tank as shown.
was thinking the same on some kinda top support. The factory only had a single strip of a 1x2 across the top of the tank.
kcassells
Ahh you'll figure something out. :]
On mine I knotched the top sides and placed neo on bottom and screwed glued them in. Where there were more gaps I added more neo.
Drivewayboater2
Update
been a while since we gave an update. Not being able to post pics has been the reason. Like you all say “pics or it didn’t happen” 🤣
Nonetheless progress has been made
fuel tank installed
very pleased with the fitment.
installed the rail for the floor and glassed the floor back in place
installed the rehabbed side vents. Wet sanded, compounded, and waxed the hull before installing.
Drivewayboater2
Thanks kcassels! Baby steps
I installed the floor back in the aft cabin. I used thickened polyester and chop strand fibers to add strength to the resin. Used a putty knife to apply the poly to stringers and bulkhead. Then placed the original piece (cut out) back to where it was. I’ll run some chop strand mat pieces over the seam. That’s the plan for tomorrow.
While I had the extra room (3 inches😂) i used oxy clean and a scrub brush on the monkey fur. For those trying to get rid of old stains this method worked awesome. I did use a wet dry vac to really get rid of any moisture residue after scrubbing. It dried quick and smells a ton better in the aft cabin.
A few weeks ago I re installed the re manufactured bow pulpit. Of course I took the time to wet sand, compound and wax the area before installing.
kcassells
The anchor pulpit turned out really nice. Is there a windlass involved or going manual for starts.
